Just got back from a big hill run birds, hands cold and balls numb :( (dem bike brakes)
We gotta start doing our late night runs again, mate just got a ninja 300
Edited by UNR33L
I will join you guys... Just answer me pls
/bikelinesaustralia brahs, want to post up / pm me rough costs for picking up and starting down the road of motorbikes? E.g. rego, insurance, gear, maintenance? Getting keen again. Have researched a bit but always good to here more accounts & opinions.
Thinking of standard learner bikes like ninja 250, VTR250, or gs500f... not the fastest I think, but still cool and good resale?
I should probably save my money... But live it up while I'm young and get one anyway? XD
Even if I go through with it - couldn't afford a Ninja 300... would love one though :'(
Yea just get a ninja 250 or something like that to learn on for a year wont loose much money, rego is like 400 bucks for a 250 and insurance just get third party which is probably like $150.
Gear wise you'll need helmet $300-500 (mine was like 480, could spend upto 1k if you want, depends what fits and feels good), kevlar jeans like $200, jacket is $4-500, gloves $50-130 and I'd recommend getting some boots when you can afford them say $200-250 for normal ones. TBH gear really depends on what you want to spend, but personally i'd set aside 1-1.5k for gear.
Pretty much summing up what I thought the costs would be like! Looking pretty positive so far :D
And hoping can get one with decent amount of rego so I can avoid paying that even / getting absorbed in bike budget.
With insurance, is there a difference between third party, and theft? Noticed insuremyride separates the two...?
Did you buy your gear online?
Ninja 250 tempting. OR do I go oldschool boyracer (boyrider) and gamble with a CBR250RR (not thrashed at all )xD
3rd party, you hit someone else your insurance company will pay for their damages but not yours. Theft, your vehicle is stolen, they'll pay you out for agreed or market value depending on your contract.
guys, me need your help with a school research project, its on energy saving and stupid shit like that.
would appreciate if you guys would fill out this survey, i need about 10-20 respondents.
https://rmit.asia.qualtrics.com/SE/?SID=SV_1WZBm7BSp5eNAax
Alvin, you seem to have skipped inputting multiple answers for one of the questions....
What temperatures is the air conditioning set for normally?
  • Click to write Choice 1
  • Click to write Choice 2
  • Click to write Choice 3
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
