completed. my current swedish housemate is not very energy efficient. nor water wise. Its hard to say something because im sure she'd think im just stingy.
It usually takes me about 6 months to get sick of a housemate. Good thing shes only here for a semester. My pet hate: leaving the toilet seat up. and I swear she goes out of her way to leave it up.
3rd party, you hit someone else your insurance company will pay for their damages but not yours. Theft, your vehicle is stolen, they'll pay you out for agreed or market value depending on your contract.
Yup. But I meant when people suggest and recommend 3rd party for bikes do they really mean without theft cover? Or to look into ones with both lols
Pretty much summing up what I thought the costs would be like! Looking pretty positive so far :D
And hoping can get one with decent amount of rego so I can avoid paying that even / getting absorbed in bike budget.
With insurance, is there a difference between third party, and theft? Noticed insuremyride separates the two...?
Did you buy your gear online?
Ninja 250 tempting. OR do I go oldschool boyracer (boyrider) and gamble with a CBR250RR (not thrashed at all )xD
Yeah theft is like an addon for like $80 extra or whatever, I would just be standard and get the 250r like everyone else. CBR250rr is old junk.
And no don't buy any gear online, go into a peter stevens, try it all on to make sure it fits snug - if you buy it all together you'll get some decent discount usually too.
but why do you leave it down? do you sit down and pee?
the toilet seat in my house is always up. until we need to take a shit, then it comes down.
Hate to break it to you dude, but chix with dix are living with you... What possible reason would a woman leave the toilet seat up for?
Are you talking about the seat (ring) or the cover that goes on top? No reason to ever put the cover down unless you've got new kittens running around who might fall in.
I think he means the lid fellas and I hate this also, for 2 reasons,
1..I dont like smelling a stinking toilet bowl everytime I walk past it
2..the dog drinks from it, then the missus yells at the poor dog..well if you put the f**king lid down you slackass.... :rant:
close the lid or close the door..i will settle for either
Oh you can add it on? 2ez.
Yeah seen fair few 250R around the ~$4K. Don't really want to spend much more than that tbh.
Alvin I'll do the survey later... have to ask my parents how old the house is, I don't even know lmao.
+1 to confusion on toilet seat, would have thought it was other way around tbh
edit: also realised besides quotes not working, multiquote is gone? and the full reply option (as opposed to quick reply) ? :S
If you clean your toilet, it will not smell... A toilet should have zero odor unless there is something wrong with it... Grab a disinfectant block and throw it in the cistern and it'll self clean and disinfect with every flush...
MOTHER f**kING PINE SCENTED UP IN THIS BITCH!!!!
Multi Quote is working fine for me, on Chrome using the Pulse theme...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
