is that all fast is..., all it tells me is my car has 2 doors, and an rb25 and is gunmetal grey..AMAZING!!...
I though it gave a list of how many owners etc...what is the point of it...?
Fast will Also tell you what options your vehicle came specced with.
EPC-Data is good but when searching parts it can be a bit confusing cus it's pretty vague with its descriptions.
For instance that link Simon posted up
20010 - TUBE ASSY-EXHAUST,FRONT
20018 - TUBE ASSY-EXHAUST CONNECT,FRONT
20020B - NUT
20020BA - NUT
20020BB - NUT
20100 - MUFFLER ASSY-EXHAUST MAIN
20651M - MOUNTING-EXHAUST,RUBBER
20651MA - MOUNTING-EXHAUST,RUBBER
20651MB - MOUNTING-EXHAUST,RUBBER
20651MC - MOUNTING-EXHAUST,RUBBER
20651MD - MOUNTING-EXHAUST,RUBBER
20691 - GASKET-EXHAUST
20692M - GASKET-EXHAUST
20692MA - GASKET-EXHAUST
Whereas in Fast you goto General Index, Engine & Fuel & click on the picture of the exhaust and it'll give you...
Where you can click on the part codes for which gasket/hanger/nut you actually need and get the part number from it.
There's a few versions kicking around the net if you do a Google search or genuine Fast discs of various versions come up all the time on Yahoo Japan.
I'm running the 2001 catalogs and 2009 catalogs on the 2012 Fast program cus then I have more models/up to date program and for some reason the '12 program runs the '09 Jap catalogues in English wish is pretty handy.
I remember trying to get it working years ago, and it was so stupidly complicated so I gave up.
16bit vs 32bit vs 64bit
English vs Japanese, no JP Character Set on my computer so JP Symbols were coming up as "????"
/ragequit
2012 Version comes in 64 bit, Jap characters will come up as gobblydygook either way cus it uses Shift-JIS character encoding instead of ANSI/Unicode and I don't know how to get non Jap windows to support it.
What will you talk about today at the conference Hamish?I've always wondered what do people talk about in one of these things.
what I do at the bank and how it effects other stakeholders etc etc
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
