2 hours left at work... Then leaving tonight for... http://stupiddope.com/2011/06/23/koro-sun-resort-vanua-levu-island-fiji/koro-sun-resort-fiji/
2 hours never felt so long (even though we're leaving half an hour early to go to a local microbrewery for some drinky drinks)
Why would u want monthly. I'm on monthly now and it's a pain in the fkn ass hole
+1 for monthly club. Considering leaving cause its shit.
Drift Ghost HD - $450
extra battery - $29
Rollbar mount - $39
SDHC card 32gb - $50
hmmm starts to add up doesnt it.
Monthly because he has to blow his first pay cheque, therefore more money blown on blackjack and hookers than a fortnightly or weekly salary.
/strongawareofallforumjokes
my rent is due 4 days before payday, so have to budget whole month. bills are usually here and there.
so mine was meant to be 2 days b4 pay.
so when I moved in talked to land son of rajab, and first rent payed 1 month and a week.
and then it now due 5 days after pay every month,
Understanding folk at my estate agent.
I think he means the lid fellas and I hate this also, for 2 reasons,
1..I dont like smelling a stinking toilet bowl everytime I walk past it
2..the dog drinks from it, then the missus yells at the poor dog..well if you put the f**king lid down you slackass.... :rant:
close the lid or close the door..i will settle for either
I close the door and leave the cover open. Otherwise the cat pulls all the toilet paper off the roll.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
