Yes it is. I'll do it, need some moolah :P
I love black carssss
Do mine, but at my house, and for cheap cause I just spent enough money atm :P
Looked like that hurt, although the other guy that caused it seemed fine
So... I'm thinking I had a few drinks tonight.
ended up watching fast and the furious for the first time in many many years.
first off I was surprised just how much I noticed compared to first time, ie crappy parts (mainly sparco) that I would never put on my car.
then I started thinking just how do you end up in the "scene" ie how did you end up getting into jap cars and modifying them, as 10 years ago I was all into US muscle, hell still like it but yeah.
first experience I had with Jap cars, one of the guys I worked with took me out to a MCCR "street race night in his heavy modified MkIV supra.
one thing lead to another and I've spent way too much on playing with cars since...
so what got everyone else into the addiction?
Always kinda had an interest in all sorts of cars as a kid, for some reason Jap cars I remember always drew me in a bit differently, then all that FnF/Hot4's/NFSU(I was what 11-13 gimme a break :P) shit was big and I guess that moulded my thoughts a bit more then it's just grown and grown from around there.
This is why whenever I take people up my mountain run, I drill it into their heads to stick to the left of the road and not take the racing line. Too many cars go half a metre over the line on a tight corner. Sometimes you just can't avoid it though...
Used to be into 4x4's until I was what 11 or 12 when I first saw a car flying past with distinctive taillights - it was a MP 33 GTR. As I grew older with introduction of Autosalon mags and shows, FnF etc, bought first car which was a Patrol with 30ET inside (it hauled real good) thinking I'm still into 4x4's. After I'd sold the Patrol and rest is history.
/csb
I have half of the Street Machine issues ever released...thats over 30 years worth..I think my oldest 1986...
old man had a monaro.. I bought one too but couldn't be f**ked fixing it....I ran into an old friend with a skyline for sale, he let me drive it, i had cash...end story
Wouldn't say I'm addicted...
But I had seen the odd R33 on the road as a kid and always thought they looked cool. Then mates in year 11 properly got me into Jap cars with their talk of Supras and 180s. Then a mate with a Civic on his Ls introduced me to MCCR. Then I saw a 180sx cruising on the road with a CV8 Monaro (they were new at the time) and I was like...I have to have one. Parents said no :(
if your still spending money on a 33...then sorry to say your addicted.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
