big call
I know, but...things I learnt from that article:
- Hot hatches and utilities share the same target market
- GM managers are professional drivers
- 13 seconds variation across a 21km circuit is the difference between fast and leisurely
- Shooting for fastest ute around nurburgring (assuming it was the intention) and clocking slower times than non-utes means your plan backfired
- Hot hatches don't handle well and were designed for grocery shopping, not corners
I know what you mean Birds, but at least it's better than the usual drivel from cars guide. especially the 'ask smithy' smithy. "my car is 2yrs old and has problem X" smithy: "hmm we get a lot of letters from people with problem X. return to your dealer an see what they think"
didnt know Holden ute was on springs
- Hot hatches and utilities share the same target market well you can put stuff in the back of both
- GM managers are professional drivers Holden do have certified Nurburgring testers who are apparently the only ones allowed to test cars there, (according the wheels magaine last month)
- 13 seconds variation across a 21km circuit is the difference between fast and leisurely tell that to the person who came 2nd
- Shooting for fastest ute around nurburgring (assuming it was the intention) and clocking slower times than non-utes means your plan backfired if this is your Renault then yes..
renault-sandero-stepway-pickup-projecao.
- Hot hatches don't handle well and were designed for grocery shopping, not corners obviously
yes I'm bored
3 things...
1.Joshua looks like a Renault Megane driving shirtlifter, which explains the retarded article..
2.Lets see the Renault do a burnout, tow a boat, sell affordable spare parts etc etc...
3.That ute is f**king ugly
so what got everyone else into the addiction?
I've got a bit of an obsessive personality. At first my interest was music, one band in particular. I spent every moment living and breathing them. Then it was computers, same deal. And then I bought my first car. This one hobby will stay with me for life though...
Changed to BCPR6ES-11.
First time giving it some it slightly misfired then stopped and now coming back.
Funny because when it happened, I gave it some again and it got better. By the 4-5th time going at it it pretty much stopped misfiring but just a quick little hicup at about 5k rpm.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
