I'm only running fmic and exhaust, boost sitting on 9psi after those mods.
Thought I'll be alright with 1.1mm since not running much power, shall re-gap to 0.8mm and perhaps coilpacks.
Misfiring better go away before deca!
If you don't have new coilpacks forget about 1.1mm
Yeh mate, 6 burner + Teriyaki hotplate + wok burner, with a side sink/chopping board. Runs twin gas bottles. lol.
two of the big ones..
i would be glad to come around with wagyu, but need to tend to jess.. as the drugs wear off she is in more pain lol
just use bscp6es or bcpr7es and gap to 0.8 at all times...
this has been the most proven plug / gap combo on SAU for like 10 years for almost every conceivable application.
I do not even come close to understanding why people insist on running 1.1 and then spend days arguing their point on the forums when it has been proven to be less effective, time after time after time.
we have this wealth of knowledge (including an 11ty billion page spark plug thread) for a reason
im planning on buying a Ghost HD next week and just thinking about using a GPS Laptimer and then overlaying the info to the video... Reading through a bunch of product pages (http://www.gps-laptimer.de/Features.html, racechrono) and none say if the footage has to be recorded with the phone or if it can be merged with a mpeg or something.
How does everyone else do it?
Track vision is a $150 program for PC that will let you merge the info... but you still have to record the data and film it as well :|
Yeah double check Anthony, you still have the standard boost solenoid don't you? Definitely unusual to spike 4psi with that.
Yeah definitely hitting 1.5 bar on full boost according to defi gauge
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
