will def try the bbh if i'm ever in st albans... but i cant see myself being in st albans for any reason, EVER
that place is a fkn hole
Damn straight its a hole. But dayum. Dat bbh.
Alvin agrees. Ive converted him. Haha. Makes the 50 min drive just for bbh now
Anyone here know about this?
http://news.ninemsn.com.au/national/2013/05/05/13/13/two-arrested-after-melbourne-kidnapping
Now they're getting stolen with people in them :/
That's why I always lock the doors as soon as I get in the car....
Was stopped by a druggy once at an intersection asking for a lift and threatening that my family will be in danger if I don't give him a lift, so I sped off with him missing a punch to my car... westside!
I've decided to sell my S2000 after only 10 months of ownership. Over the past 5 months it has been: side swiped twice (only once did I get a note), reversed into, had tyres let down, reversed into by an old lady, then today....
Sad day because I love the car so much. I plan on owning one another day when I have a garage and don't live in scum town. For now it will fund my European holiday later in the year.
This is why I can't have nice things.
lol I bet your bike is dirty as shit and it still looks clean in that colour...
Mad invite brah
Indeed it is very dirty!
Would you of actually come this time? :P I'm sure there will be plenty of rides coming up!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
