not really...
it's 285 on that wrecker motor which is temporary... it's just testing it.. he has another motor which it's all going onto and will be tuned more agressively...
trent is guessing mid 300's....
which i'm afraid son... in a 1300 odd kg VN / VP commo... will place your 370rwkw squarely in his rear view mirror :P
Nah he'll be right, Leigh's are roller dyno figures :P
Im not going to bite on the dyno comment... Although I will admit I do want to :P
I don't think you guys appreciate how much difference 400 kgs really is...
For an equal power to weight that car actually only needs 280rwkw to be on par with Leigh, and any more is gravy
If that car makes 350 we are talking approx 270 rwkw / tonne vs Leigh's 210 odd
That is stupid quick....
Although being a commo it probably has 400kg worth of subs :P
my car used to have 400kg worth of subs in the boot. i removed them and it made no difference to how the car feels.
on a side note, would you be interested in the guts for a 2.3 kit or a big ass turbo kit for your emo?
Nah, not building the evo....
Also, there is no way 400 kgs would not make a difference
lames.
know anyone that would be interested?.
my car has the worlds most retarded tune on it, you could be out dragged by a mobility scooter from a standing start. no guts at take off, flat spot at 2k, goes ok for a bit till 3k then flat spot agian, then takes off after 3k.
taking the subs out made no difference to how that series of events occured.
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
