Vic Wasteland Thread
R31Nismoid
I'm going the 8mr turbo route... May do cams, may not.
Response > power
Response aye.. I hold the secret answer! :P
Nah but srs cams are cool
Edited by UNR33L
you dont have to use tags, you just fail at pasting the links in the correct way.
that honda sounds more like its running rotational idle rather than cams.
thats with standard cams.
its used with antilag to help cool the engine and exhaust down by keeping the throttle open and idling at ~1700 then controlling the revs by only firing a few cyls on a rotation rather than all the time. #themoreyouknow
Blown diffuser sound :) very good technology. (Banned now in f1)
some teams had different ideas:
Edited by UNR33L
lmzo, vid i linked is from TODA's vtec killer cams. that honda is a n/a brah, running straight from throttle body.
do want ported 20b.
Guest
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
