Vic Wasteland Thread
R31Nismoid
C class is pov? News to me top bloke in an outdated skyline
im sorry my car isn't trendy enough for you...but being fashionable never was really my thing...
anyway catch me if you can biatch! ...oh wait, just let me put my turbo back in :/
LOL!
That's a crap load of power
When you doing your next track day?
Sandown next weekend, DECA in June, then hopefully PI, then Sandown again with Driver Dynamics in July.
Thats fingers crossed my car doesnt die majorly. Which is a possibility.
Good work, keen to see what sort of times you run at Sandown
my first time out was a 1:32 but expecting a significant chunk off with my new coilovers, proper alignment and practice.
yeah rebuilt disco potato.
Got a mechanical LSD in the 'box with straight-cut gears, which helps traction in corners.
Traction is ok as long as you dont launch like a moron, but torque steer is a different issue...
Good work
Should be out racing with ya in a few months
Just look at that sitting stance, you can easily tell he enjoys the company of other men more than that of the lovely lass next to him.
Just like looking at this thing.
that would be tractive effort not torque man...torque is probably around 400nm
this ^ a tuner once told me you can't really measure torque 100% accurately.. had some reasons which ive not forgotten
Guest
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
