Natural instinct to create a sense of dominance but I agree totally, argue quietly...much better chance of getting your point across than shouting like a f**k.
Just got back from Princes Highway. Police everywhere left right and centre pulling cars over. Why cars cruise up and down there is beyond me if your afraid of getting a defect. Kinda like musical chairs with the cops on who they will pull over.
Fun to watch though.
i assume you weren't in the 34 then.
Evening friends, greetings from Denmark. Been on the road now for around 4 months and in total I've seen 1 skyline... And believe me I've been on the lookout.
God bless Australia I say. What's news around here? Any cool / exciting stuff been happening?
yeh my mate chucked a pic up, what was so special there last night?
also ps3 v xbox? thinknig to get one leaning toward ps3 but dont really know since the last game console i had was a ps1 !
also should i wait, as in any newer models coming out? ps4 or something?
I was went there to check it out with mates, then went to eat there.
Shit was intense. Trying to leave home was like being the guy from Prison Break. Mr Po po everywhere.
If you dont have a bluray player prob go the ps3.
Also to play online on PS3 dont need to pay for a subscription but xbox you do, if you dont care about the above 2 things then it just comes down to what games you want to play. GT5 vs forza 4 etc.
Was supposed to be a "new" night so they had a lot of well known DJs and heavily promoted it. Looked like same old ethic night @ CQ to me. Gotta give props to the organisers though, I was there a month ago and the place was pretty dead.
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
