sorry but that looks horrible...needs more dish..
nice clean car though, is that what your is...when do I get to do my thing to it.. ...?
and it looks like stupid...
I just dont like the stretched 255s he has on it, prefer the fatter rubber for the tuff look. He won't be able to get a decent sized tyre on thats for sure.
Similar to mine, yea - I've been really busy at work lately I'll have to let ya know when things settle down, off to Tassy this whole week kinda cbf :(
Played one game..
Game finished!
You got 9651 points in total.
Half of them you can almost figure out from the sort of cars big trucks obviously I put like Texas but was Canada :(
would look sweet as with some SSRs or something similar on it..and yeah fatty rubber ftw
Yeah I really want go get some nice meisters on it or at least "fake meisters" maybe when my tyres run out i'll go down that path.
"Real" rims cost a shit load in sizes like 19x10 in good offsets
what size are your stock rims on it 19 or 18 ?
theres a fake meister style wheel black with a bronze lip could look hot...
clutch suggestions.
need something kinda soft since my left knee is f**ked.
but im not a saudi sheikh so something affordable lol
how much power...NPC ones are real nice...cheap too...
ill sell you my meisters.
hey Mo where did you get the wheel bolts from when you redid those rims you had.you got nice chrome ones yeah...I finally pulled those RS evos I got off Mig apart...but shredded a few bolts doing so...figured i'd replace the lot
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
