gym to get fit... it's not a dick measuring contest. fk weights
Weights will get you fit too... In tandem probably best bet imo. Unless you just want mad endurance or something :S
I dont see why the government needs to throw cash to try and keep a failing company afloat. The industry has had many years warning to shape-up and change and they have done too litle too late. Territory was successful, but need some serious movers and shakers by that point. They played it 'safe' and now theyre bust. I do feel for the employees though, government money should go towards them and not ford (if there was an option and government were gonna splash the cash anyway)
My reasoning is 2 fold...
1) I give no farks for weights or impressing people with what I can lift
2) I have fkd knees and left elbow, so i'm pretty restricted on what i can lift.
I might do some core stuff eventually, but really I just want to get fit
Well said.
At least the employees have a decent amount of time to secure new employment in this instance.
ford shutting down production in aus.. if government gave them as much as they did holden that may not happen..
If they made decent (smaller) cars for a reasonable price that people liked the look of, they wouldn't be going under.
Toyota can't make enough FT86's... Styling must be the key. I doubt other manufacturers will learn from Ford's mistakes though.
Ghost camera wont arrive before sandown... delays due to tornado. Forcast is slightly improving for weekend... itching for some track action. Passenger bucket seat is almost ready :)
..work...going...too...slow...
Had a photoshoot.
Strength training makes you fit and shreds fat.
Ford Australia going under has more to do with local product struggling to compete against conglomerate manufacturers in other countries employing people to work for SFA and...in the grand scheme of things...the mentality behind you buying your shit from "eBay anywhere but Australia" because it's the cheapest you can get it.
In saying that I'll be having macca's for lunch
I had a Chicken Schnitzel Sandwich, with Cheese, and ham, and tomato relish....
Ok, so it was pretty much a parma sandwich. I'm alright with this.
Been to Schnitz at Knox? They do this!
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
