Oh if she doesn't mind being around meat, go to Papparich! It's cheap and it's really good food. My gf is vegetarian and liked the stuff they had there.
Awesome, do I need to make reservation on Sat for lunch? Or would I be good to rock up?
So much for Evos being the new import to own. Craze lasted like 6 months, now everyone hates them lol
I like the evo, it's just gutless... which I plan to fix when i have ca$h
that's why you buy an entertainment book, buy one get one free so it does cost $5-$6 a burger
276251_Papel-de-Parede-Meme-Are-You-Kidd
chef's don't do entertainment books.
I thought if you used one of those books the chef spat in your food.
or at least used yesterdays leftover ingredients they were throwing out
not spit....
but you will definitely get worse food...
chef will definitely cheap out on the food though... portion size, expensive ingredients and effort. you will also get the oldest, shittest piece of steak/fish etc.
They will also either push the food out right away to get you out and a paying customer in, or put your order to the back of the queue.
I did this every time. without any guilt.
and before you get all up in my shit about it, think about it from the chef's POV
1) people that use the guide are not return customers, they only come once a year at best.
2) even if you try to give them the good shit and it's awesome, they are most likely to go to somewhere else next time to use more vouchers
3) better off to keep the good shit for your core customers, that spend more and will return.
4) experience shows that most of the time they come in, use the voucher, drink free water or 1 glass of wine at best don't tip and are more likely to be rude to waitstaff.
I see where your coming from but:
Why does the owner then advertise in these entertainment books?
If it is for increased advertising of the restaurant then surely it is in the best interests of the restaurant to serve good food to the customer so word spreads.
Disclaimer: Have never owned one of these entertainment books
overall it's a profitable venture... nothing like a restaurant full of paying customers every night though..
end of the day it's guaranteed custom but at a lower return than real customers
of course... that's restaurant tactics 101... but it goes a lot deeper than that in practice
you have to hedge your bets, so you do.
also, work in restaurants for a while and you start to notice that a high percentage of voucher customers complain about every little thing possible and are never happy anyway lol
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
