When people say they need to run 1000cc injectors for xxxHP. that means 1000cc each injector right...?
Some noob on ozhonda keeps saying that when people say 400cc is needed for 400hp on E85 on a 1.8L 4cyl. He thinks that its 100cc injector per cylinder...
So he says he needs 1600cc injectors for 400hp e85 n/a, which in his mind means 400cc each injector. Lmao, confews...
It's per injector. Engines with less cylinders obviously need bigger injectors to flow the same as engines with more cylinders. So Nismo 555s in an RB will still flow a bit more than Nismo 740cc in an SR.
400cc injectors will NOT cut it for 400hp in a 4 cylinder engine, particularly on E85. You would need 740cc at least and that may be maxing them out. ID1000s would be a good choice.
yar yar. i confused myself a bit in my post. He said he would need "ID1600" for 400hp, which would be "maxing them out" (in his mind 400cc per injector). We were all wtf, because 1600 more than enough for 400hp. Turns out he meant ID400. Got that stubborn mind where when someone states xxxCC injector, thats the overall CC for the whole engine. Lol
it is a legit fix, rice absorbs the water and fixed the device.
better would be the stuff they package in electronics and such but hard to find in bulk.
make sure device is off, leave for a couple days in rice..fixed.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
