yar yar. i confused myself a bit in my post. He said he would need "ID1600" for 400hp, which would be "maxing them out" (in his mind 400cc per injector). We were all wtf, because 1600 more than enough for 400hp. Turns out he meant ID400. Got that stubborn mind where when someone states xxxCC injector, thats the overall CC for the whole engine. Lol
facepalm.... please never talk about injectors again... my head can take only so much
The guy that used to own that car
i lol'd
social engineering 101. Need to take advantage of sau cred and/or strong referral for maximum response.
Aint no body got time for random unknown emails/calls
No you don't...
Ain't no body got time for random unknown emails? Aaron does, he's running a business.
Either PM him on Facebook, email him or call him.
If you're interested in doing business with him, he's interested in doing business with you, or Import Monster would have gone bankrupt years ago.
No you don't...
Yup and that's why I'm looking for a direct contact to him as opposed to a generic email address :)
FWIW import monster cust service is impeccable
I emailed them on the support @ import monster or whatever address, not to buy shit, but to get my money back as I had excess funds in my account.
I got a return email within the hour and the funds deposited then and there. available in my acct the NEXT DAY
suck it up and email him the way he want's you to unless you need to have a lengthy chat about importing a car
When people say they need to run 1000cc injectors for xxxHP. that means 1000cc each injector right...?
Some noob on ozhonda keeps saying that when people say 400cc is needed for 400hp on E85 on a 1.8L 4cyl. He thinks that its 100cc injector per cylinder...
So he says he needs 1600cc injectors for 400hp e85 n/a, which in his mind means 400cc each injector. Lmao, confews...
Honda people i swear...
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
