some guy tried to grill me on an email and CCed my manager and branch manager
cbf writing a reponse on iphone but tomorrow morning I'll definitely be returning fire pissed me off especially when I'm not in the wrong
I wanna see this shit...love office politics when I'm not involved.
Yep some people need a clue.
Never met the guy but apparently he's old, so why try and grill a young guy that knows what he's talking about when it comes to technology? Should of just called me if he had a query for starters which he didn't. Apparently "wasted" him and another guys whole day trying to figure it out. Should of taken 20 minutes if he followed my simple instructions. Makes me angry over such a simple stupid thing. I bet the managers are laughing no response from them yet.
I'll laugh with my boss tomorrow about it for sure.
I'm tempted to login to his webmail to see if/what his manager responded to him with. Don't mess with us I.T folk we have our ways :P I wont though.. have morals!
Edited by UNR33L
Never knew Repco made filters.
On your skyrine? Any problems or difference?
Just need to change oil before deca this weekend.
yeah repco on mine...from what I've been told by guys that have chopped them up they are actually better than ryco filters....also a couple bucks cheaper....
Some Autobahms/bursons Have Greddy oil Filters. I Quite like them
Goodes is a pathetic little bitch who needs a good belting...
You guys have called me an ape/gorilla before due to my beard and did I complain / storm off like a bitch? No... Because unlike goodes, I am actually a man
Puts on tin foil hat....
There is also the distinct possibility the media have blown this out of proportion in a deliberate attempt to take the attention off the improper treatment of the 13 year old at the hands of the police...
Removes hat...
haha can only imagine how much fun you can have when you control the I.T
Im friends with my IT support. In return full admin rights on my laptop...woo! /installalltheprograms
You guys have called me an ape/gorilla before due to my beard and did I complain / storm off like a bitch? No... Because unlike goodes, I am actually monkey magic
fixed...
haha yeah sometimes has its advantages, if people are nice i do them favors
Guest
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
