i've been sleeping 4hours/night for about 3 days straight.
assignments brah. dat unilyf
and now to head to school, because some excel sheet with macros doesn't work on excel for mac.
4 hours sleep is bad ?
I go to be 11ish every night and get up for work at 3:30am
4 1/2 hours sleep then 10 - 12 hours work everyday all for a slightly above avg wage
baker? butcher?
baker? butcher?
I work for Auspostget around 48k a year.
Thinking about leaving and become a PSO.
well you are really going to hate me for this... but...
the average wage in Australia (from the Bureau of Statics) is....
wait for it....
keep scrolling...
nearly there...
$72,800
i'd say it's more likely from executives and public sector employees etc.
if it was the mines lifting aust then WA would have the highest average, however it's currently Canberra @ $85k
$5.2 million dollars just to get e-tax working on Mac aye....
Sounds a bit Myki to me
Eh.
Tony does mine lol
Jah mun
the Median wage is $57k (in aust) which is a more accurate representation of the average australians actual pay
Yeah that seems a bit more realistic
If you don't get enough sleep in a day. Go to sleep earlier. just sayin
UPDATE: EDDIE McGuire will meet Collingwood chiefs to decide if he should stand aside as president after his "King Kong" reference to Adam Goodes.
Read more: http://www.news.com.au/#ixzz2UjM6dUiU
Guest
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
