& also lol Alvin, I handed in my last assessment due on Tuesday night... and that was for an Arts subject. This semester has been alright assessment wise... but just means everything will be riding on exams, fffuuu.
Haha nice sig also.
still got 3 more assignments due this sunday/monday morning. And spent 12 hours in school yesterday trying to remember simulink.
and i've got one paper, right smack in the middle of the exam period, if it was earlier, i would be able to go to brissie earlier.
and because there aren't any nice azusa ones on animesuki, i'll just have to settle for tsukiko.
Sounds balls, bro. Hang in there. On the plus side, it's just the one exam huh? (Besides it's less-than-ideal timing). SOON it will be over.
I rate tsukiko over azusa anyway. *shrug*. Poker face lulz.
not too fussed about it anyway, its an easy paper, since i only really need a 40% in that paper.
and, even though i like azusa more, i'll have to admit, tsukiko is very cute too. and cute works for me.
SYDNEY coach John Longmire has not ruled out Adam Goodes not playing this weekend due to his distress over the racism saga.
The Swans host Essendon in a blockbuster on Saturday but the two-time Brownlow medallist is still no certainty to play because of Eddie McGuire's comments linking him to King Kong.
It comes on the back of last Friday night's incident at the MCG where Goodes was labelled an "ape" by a 13-year-old Collingwood supporter.
Longmire says the club and Goodes are taking it one day at a time.
ok... Goodes doesn't need a slap... he needs a fkn bullet
In time you will, as the other Victorians have, get used to Hamish hating absolutely everything that was not initially spoken of, or better created by himself
So hamish was a Hipster before being a Hipster became too mainstream.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
