last batch of exiges went from 180,000 to 110,000 in less than 10 months, and often the low volume sales with optional extras means that many are unique to Australia. eg. there are only 4 black exige S' in Aus.
however, with the new in-house engine, servicing and parts will be interesting, really depends on how long the motor stays in production.
also, I remember when at a DECA one of the Elise's damaged the fibreglass panel at the front, which was like half the front of the car. $10,000 to replace new. not sure how much a patch-up would have cost.
but from someone who has seen, but never driven one, it's a great car for the mooney
one of the sau nsw guys has a non supercharged exige and he likes it.
wouldnt pay the brand new price, used they arent so bad.
Can someone aware me if your skylines have compliance plates?
I couldnt find one in my engine bay
Just need to prove to vicroads of the date of manufacture of my vehicle
Nissan fast shows it as May 1998. But might need a letter from Nissan for more substantial evidence
Fkn aye!
Found out I don't need a VIV certificate to register my car as there is a 15 year exemption for it
Dat benefit of owning an old car lol
15 years? That's cute. Come back to me once you've grown a beard. 20yrs and counting haha
That Lotus is amazing and considering how good value a 35 is compared to other supercar offerings, that thing will probably hold its own for 40k less. Either way, I can't afford one right now :(
owning a r32 isn't THAT bad man, chin up
Yes it is.
Guest
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
