I was in a meeting yesterday with civil engineers talking about how to dispose of oil an PCB contaminated soil. if te tests come up ok, they can mix it with 2% concrete and bury it :/
on a side note, I got a message from a pulsar guy that he is currently importing a GTiR long motor from Japan that has been built with tomei parts and strokes to 2.2, and would sell it to me if I want it...
i remember doing an environmental module, about bio remediation on oil and pcb contaminated soils, not sure about the mechanics of the whole process as you know how uni modules are, they just scratch the surface and give you a degree at the end of it all, knowing not much more than before enrolment.
that's what I liked about TAFE, rather than spending countless hours over the time of the course learning about how formulas transcribes to what we want to do with it, they just gave us the formula and said now apply to these scenarios... dodged a lot of calculus. we all walked away saying I can do that, but I can't tell you why it works
Lotus Exige S - V6 Supercharged ; 258kw @ 1100kg ; 0-100 in 3.8s
$140,000 - worth the money? /discuss
so assuming 220rwkw @ 1100kg = approx 200rwkw/tonne
my view is that the 200rwkw / tonne is the power to weight milestone a car needs to reach to be in the serious fun zone....
equivalent in other cars people will be able to relate to:
ke70 - 160rwkw
mx5 - 200rwkw
s chassis - 250rwkw
gtst - 270rwkw
evo - 280awkw
gtr - 300rwkw
recent v8 falcodore - 360rwkw
I'd say yes, it will be extreme fun and decent value compared to itallian offerings, but nothing i'd look into.
considering what you could have for a track day for $140k its bad value.
and no i wouldn't even dream of using one for a daily/track car
in b4 leigh dickbags on about v8 torque and how this somehow makes up for the car weighing more than the third moon of jupiter
(every one of those cars has a unique feature that puts them ahead of the others in some way, which is why i chose them)
oh haha, thought there was more to it. Like Leigh being denied warranty for breaking something.
Ford built tuff! (hopefully don't break anything next week at the drags)
long live teh GT
don't speak too soon.. the GS came from factory with a dicky water pump that will probably need replacing
i'm not even planning to go for graduation.
from all accounts, its just a pointless waste of time sweltering in a hot and humid hall.
I didn't originally plan on going, but knew I would regret it later. and keeps family happy
Fkn aye!
Found out I don't need a VIV certificate to register my car as there is a 15 year exemption for it
Dat benefit of owning an old car lol
17 years here brah
2pac was still alive when my car was new shiiiit
Alvin, any luck with grad positions?
Got nothing from my end..... :unsure:
This is why I like to ask people how and why it works, just for the lolz. hahaha
Didn't go to my graduation, Just got my stuff send in the mail
Stuff waiting around all day just to go up and receive your certificate for 10 secs!
Guest
    • What a wonderful journey to read. Loved the photography. Literally found this an hour ago and couldn't stop reading, plus checking out a couple of the links. Was interesting as you had a few mods very similar to my sons Gtt, including the sheetmetal homemade V-Spec II rear diffuser, can't be too many of them around the world. Only to find it sold about three weeks ago. Well at least I won't have to keep re-visiting for updates. Anyway, well done on not just the car but the well written story and descriptions, and of course the pics. Good luck on your next one. Rob
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
