What's been cracking wasteland? Went to deca and had a blast in the wet, never knew how much fun it was spinning all 4 wheels through 1st and 2nd was so much fun.... now to chase power to do it in the dry.
I've heard the loophole that I can say mines a replica of a 1988 model and can get club rego for my 1993 model!
orly?
stripped my RB26.
head looks like its in top shape.
piston #3 is f**ked just above the ring
bores look okay though? wtf?
orly?
stripped my RB26.
The Victorian club permit scheme allows members of car clubs (including motorcycle, trailer/caravan and machinery clubs) that are recognised by VicRoads to make limited use of historic vehicles on the road network.
A club permit can be issued to the following vehicles in the following categories:
  • Veteran vehicles – manufactured before 1 January 1919;
  • Vintage vehicles – manufactured after 31 December 1918 and before 1 January 1931
  • Classic and Historic vehicles - manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit.
These categories can include trailers and modified vehicles such as street rods. Vehicles which are replicas of vehicles in the above-mentioned categories may also be issued with a club permit.
keep the 20 in there until you can afford the 25/6 box
you will only destroy 20 and have to replace it.
better to be able to sell the RB20 & box as a package or to sell an unbroken box on it's own complete as opposed to small metal fragments
Guest
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
