done it.
they want to know EVERYTHING.
this is pretty accurate....
when I started at the bank they did a 5 year check and it was a nightmare.
my job that I had 4 years and 11 months prior was in a restaurant that had shut down and still wan't good enough. ended up having to resubmit it a couple of weeks later when it had moved out of the 5 years
Nice work. Mate of mine works there I think (or maybe it's DSD)
I've done one of the security clearance things, it's long but you just have to cop it lol
It's unpaid work for 3months though.... just need some experience and a foot in the door to get known. Not sure how I'm going to survive with no moneeyyy. :-/
done it.
Yep, including all info about family.
Did the security check take 6-8weeks because that's what I've been advised.
about that, yea.
depends where you are going for work afterwards, if its somewhere that needs the clearance, already having it is a big plus as they dont have to organise or wait for it.
if you have to go pos vet, just /wrists and end it.
no one likes to dig up 15 years worth of past employers/housing/etc
OK so security clearance.
The Australian Government Security Vetting Agency
these are the guys I work with as I'm the security Manager at our site.\
we have staff go though Neg 1 vetting,.
they check:
full family esp if any over seas, so parents siblings etc
full finance, all loans, debts, income, strange expenses etc
travel for the past 10 years..(i'm redoing mine atm, and with 50-100 OS trips such a pain)
all places you have lived in past 10 years
school/uni grades
they will contact ex teachers friends etc to get a feel for your charature
questiosn about drug actions
partners and such will get a mild BG check.
then there 2 levels of security higher.
so similar info just for longer and more back ground
all I can say is be honest.
if you smoked dope for a couple years admit to it, as if they find out you lie it worse than saying you did it.
that said better if you didn't
multiple speeding fines not so good.
multiple drink driving will fail you
any criminal conviction is very bad.
if you need more info PM me and I can give you a call and discuss.
Thanks heaps Martin! Will PM you if I have any questions upon. :-D
my sister went for a job with ASIO a few years ago (im sure theyll hunt me down for saying this...)
and it was worse than applying for the military. Took 8 months to get to round 3 or something which is a flight to canberra for an interview. Went through all detail Martin mentioned plus more, social networking sites, previous relationships, IQ and psychological tests. Didn't get the job anyway or didnt hear back and just moved on with life. I was more concerned that the government spends so much money investigating possible employees and spends so much time and money doing it, only to never hear from them again probably because they take so long.
yeah my clearance is about the lowest level of the "intense ones"
at the time it was the highest you could get working private sector nto for the gov,
there now 3 levels above it and no way would I like to go though that.
Then more internal gov that we just don't hear about.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
