an omelette... with eggs?! :rolleyes:
and the EF3 plans? naice.
ef3 is already installed.
benny from benchmark will be remote tuning it soonish.
had to fix the wideband not logging via the ecu (fixed last night, was referencing the wrong data point), and i blew out 1/4 of the head/manifold gasket (replaced that monday morning before work) and the previous owner chopped 10cm out of the lower radiator hose so i had to replace that so the intake pipe would fit on nicely (fixed that tuesday morning before work)
the 2.3 kit parts are all sitting there waiting, just need the cashola to have it built, but im in no rush, with the ef3 instead of the gt30 its so much nicer to drive, even on the stock 2L.
orange juice for extra flavour.
Yes four stud (only need 8 for front) and yes i prefer steel over the aluminium Rays ones that have basically been stripped.
I need 1.25 thread because Nissan
mine were used on the skyline (LMGT2 wheels have retardedly small holes for the nuts)
i assume the evo is the same as the magna which is 1.5 thread iirc, which means they are useless to me. if you want them $20 posted
yeah have read good things about benny on evooz.
i would be leaning towards and ef2 or ef2.5 i think, but if you've got a 2.3 to go on later... sweet as. exciting times.
the 3 isnt what i would call laggy, it makes some positive pressure at 2k (0.1-0.2 bar) and at 3k makes ~1bar.
if i didnt have the 2.3 kit, or a skyline that was making 390kw previously, my pick for a low cost setup would be an evo 9 turbo on E85, or get the GTPumps slightly tickled version with titanium rear wheel if you have a larger budget (same as what lance has (black evo 5 making high 290kw on e85))
I bet after it comes on, it's all smiles :P
Yeah that's what I'm leaning towards tbh. Or perhaps a bbk lite (or maybe even full) / fp green if i'm searching for a bit more... but E9/RS turbo looks like srs contender for the route I take.
i looked at the BBK and FP turbos, but 2300/2500 for a high flow stock turbo, no thanks.
at the moment its only running gate pressure (18psi) so it goes but its got nothing on the skyline in terms of how rapidly it gains speed.
Nothing definate yet, Let me just check if the lady is free for din dins
Hi bubs,
How's your day going?
Would you like to go out for dinner tonight?
I'd love to go try out that Japanese place, Chiba, that my friend works at, and he's working tonight
http://www.chibajapaneserestaurant.com.au/
xx,
Simon
Reply =
Hi Simon,
There is so much going on in my head all the time and so much I don’t and can’t talk to you about. I have been trying to talk to you all week, since you returned from DECA, but I was so overjoyed to see you and spend time with you that I kept procrastinating. We have such a wonderful time together. You are the most amazing person I have ever met…
But there is something wrong with me. I can’t be with you. My heart has been severed in two and part of me is lost. I just keep telling myself that with more time passing and us becoming close, things would get better inside of me, but they haven’t. And it’s killing me. I can’t keep in avertedly hurting you, and me by continuing this. I have so much guilt about it. And so much pain.
Please don’t hate me forever…I wish more than anything, that you could be happy…but I am not the person to do it.
I love you and I’m sorry.
Dat stock spool? :P
Haha... what's the plans with Benny's tune? ~25psi?? Evo's boost monsters.
Reply = Her breaking up with me for some unknown reason... da fuq?
If srs... wtfux :(
Simon brah
That shit is whack and I knew where if was heading from the first line. I wouldn't have even replied to it; breaking up over email...
That last line is a kicker and will provide me with sufficient lulz and/or jimmy rustling for the day.
Consider it a bullet dodged early on, my man.
How long we're you with her for?
EDIT: almost forgot to ask, was she any good in bed? I would expect at least an R = 0.8 correlation for dat dere cray cray.
Dat stock spool? :P
If srs... wtfux :(
Going to leave it at gate pressure for now.
Will go crazy on it once built, don't want any chance of block windows, ain't nobody got time for dat.
I don't intend on using e85 on it at this stage, I only want ~300kw from it.
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
