Eww. How can you sleep!? ><
Can't hear em in my sleep :)
Dezz don't get pest controller will be pricey traps with peanut butter will get em in know time
Mate hooked me up with a friend of his at Rent-o-kill, getting it over $100 cheaper than the other quotes I got...
Problem with traps is you'll have a roof full of dead mice in traps that you have to clean out yourself...All the pest control people I spoke to said the baits they use, the mice eat them then leave the house and die...Only rarely die in the roof and if that happens you get em back out for a bit less $ and they'll take care of it.
I hate the little f**kers that much that I'm prepared to pay to have it done...
I loled as well Jamie :P
Wonder who wrote it, fair enough though the front on pic does look close enough
Probably Kory (guy who took the photos) :laugh:
Wouldn't blame him though... Alex did a good job with the GTR look.
Besides the people with trained eyes for GTS-T / GTR, those who are not familiar would just have probably just picked it as a GTR due to the front bar, spoiler, side skirts, FMIC etc..
How long ago was it?
Cos mum told me it cost her $200, it was 7 years ago. I'd better dig real deep.
Cost close around about $1,000 i think? This was about 4 years ago. Got some back on Private health insurance though.
Not cheap man, other people I know have been more expensive.
Everyone's teeth are different, mine where close to a nerve so was a bit more complicated.
May have to sell the R to pay for this f**king thing lol.
I hope it isn't the case!
lol was on iphone, is that the best you got? typos on an internet forum?
bahaha fat fgt got get a friend or a real job so your life has meaning or jump in front of a train, nobody here is giving two shits about you. I almost feel sorry for you after what i've heard about you, but nope not a single fk is given.
grant just get the tooth pulled out costs fk all compared to root canals an shit
I was awake during mine, can still remember the dentist hammering into to it and hearing my teeth crack.
On the drive home my whole mouth was filled to the brim in blood because I didn't feel like swallowing it :/
I got all four taken out at once under a general, felt great when I woke up. Blood drooling out my mouth on the car trip home, bandage with icepack wrapped around my head. Had a huge meal, then the anasthetic began to wear off and the pain was f*cking terrible. Not even the strongest painkiller helped in the 3-4 days proceeding that, coupled with the fact that my jaw had locked up and I could only open my mouth about a centimeter. Puffed up and bruised face, liquid diet for about two weeks (losing a bit of weight is a good side-effect.) Stitches desolved after about 2-3 weeks, holes closed over completely in about a year. All in all, so glad I got them out. Put up with years of pain. Now, nothing.
Do it.
PS. my op was over $2000, but that's because I chose to have it under a general. No private health insurance at the time so I didn't see much of that back. You couldn't be awake for having 4 out. How many are you planning to have out?
Edited by llama_au
I have one that is bothering me at the moment.
I'd attempt to pull it out myself if they weren't in awkward position, I once tried to pull it out as they were loose but they aren't now.
re; wisdom teeth. Best if they all have popped out of the gums. Easier to remove. Else, they can be applying pressure to other teeth whilst under the gums. Then you will have to go under to get them removed.
x-rays at dentist will reveal what the $ bill is.
Guest
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
