No preference, they seem to have shops all over the place these days anyway, all with 30+ courtesy cars parked out the front
Well, I've had bad experience from the Deer Park one along with another member here. The owner or in charge there is a young guy which tried to milk my money and did apparently stuff another members car on here....
Thinking I want a GS now...I'll let Leigh post his times lol
Haha yeah good quick daily with no cop troubles :D
So yeah was 2 degrees up at heathcote and track was very dewy and glazed they had to call it off just after 9 so only got in 3 runs.
first run was just sussing out the track 12.2 @ 126mph with a 2.2 60ft, really just let off line slowly.
2nd run did a 11.61 @ 126mph with 1.85 60ft (more like it but knew it had bit more in it)
3rd run bit later in the night again and you could really tell track wasn't up to scratch 11.8 @ 126mph with a lot of wheel spin then that was it.
I had the gopro on helmet so i'll post up my 11.61 run
Apart from ripping you off how was the workmanship? I'm not paying for it so cost doesn't bother me
Not too sure about the workmanship as my stolen car was towed to them until my insurance picked it up, just glad I didn't have to deal much with them.
Been to WestWood Auto Body Shop on Westwood drive, while their customer service was good, their workmanship wasn't the best. Having to get them redo my car twice before getting it to a decent level.
First visit, the rear bumper wasn't repaired properly as the cracks in the bumper were still visible. Second time it had about 3-4 drops of clear coat almost the size of rain drops...
If they're willing to be dodgy in one aspect of the business, I'd be concerned about their attitude towards other practices like workmanship too...likely have apprentices working on your car and save time cutting corners etc.
Like those horror workshops who charge people 50k to tek screw their body kits on.
11.6? damn. what tyres?
stock engine with bolt-ons (injectors, turbo, exhaust and ECU) won't crack 200 and still I cost me $600 for a tune. I'm thinking its worthy getting work done on it now while it's out. the block still requires machining to convert to FWD
got call from engine builder last night... spun 1 bearing, scoring on saddle and caps, cam lobes and springs damaged... sounds like I might have over-revved it too :S which I kinda remember doing at sandown. my shift light should get chucked in once back on the road and then get an electrical-cut rev limiter...
Street tyres nitto nt05
I reckon with some proper slicks on a good night would be very close to a 10
I love how it was one of the quickest there and I just drive home :D apparently it was pretty funny cos of how quiet the car is compared to the ones I was racing
Edited by UNR33L
Saw you drive past me Thursday night as I was turning into Knox you gigantic phaggot
Home Alone didnt have a plot twist.
Lost In Translation didnt have a plot twist.
Monsters Inc. didnt have a plot twist.
Every Stanley Kubric probably didnt have a plot twist.
Oliver Twist didnt have a plot twist.
Twister didnt have a plot twist.
The Plot To Kill Hitler didnt have a plot twist.
Joey and the Plot Twist didnt have a plot twist.
Home Alone - kid got left home alone
Lost In Translation - when bill murray's character meets a chick you expect him to fall in love with she instead makes him remember he loves his family
Monsters Inc. - the monster realise that scaring children is bad
Oliver Twist - after getting kicked out of the orphanage he ends up around criminals, which in turn reminds him that he doesn't want to be like them
Twister - dude is trying to divorse his mrs because of her tornado obsession, but then ends up chasing tornado's with her
Every Stanley Kubric - the shining.... is just a series of plot twists joined together. clockwork orange has alex turning good and then bad again. full metal jacket has private pile commit suicide
The Plot To Kill Hitler - hitler was in a room of trusted officers when one of them placed a suitcase full of explosives next to him (albeit on the wrong side of the table leg) after surviving this hitler became much more cautious.
Joey and the Plot Twist - this is just something you made up.
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
