yeah i'd prob sell for about 200, duno was keen on just keeping it and one day make a propper simulator thingy (aka when i move out)
Yeah if I get one it'll be for a proper cockpit setup, I'll probably just pay for a decent ready made one though
yeah like its alright on the desk where i can play - but thing is the brake actually has some force behind it like a brake pedal should and pushes away on carpet, plus you cant really change gears hard with the manual mode while its only mounted to a slick desk just slides right off it.
Propper cockpit setup would be WAY better
Gooby pls
I made one years ago, has a G25 wheels setup and a glass backed race seat. I loved it for rally games on the PS3, even got some stage records. You are correct, the pedal and wheel force can be higher than what you would expect from a car in similar situations.
Anyone looking for a nice setup on a strong frame with wheels, the G25 and seat, let me know, I want to sell it. No room in the house for it anymore. :/
Haha not sure. Its a year old, so not sure what versions are out now etc
Good fun
So what are your plans for the rebuild leroy?
replace everything thats broken :P
the only significant changes are increased compression from new pistons, forged H rods, adjustable cam gears (2) so that it can be adjusted lol, and hopefully a little bit of porting and other little tasks (bigger openings on oil squirters, stronger springs, balanced engine) add up to a better engine. Im doing a bit of research now in lightened pulleys but over driving is an issue and theres too many version of the FWD SR20s to get confused.
ie. VE oil pump is apparently bigger and better than DE, but while bigger than GTiR it flows less. some VE lightened pulleys require small grinding to fit on DE, but require spacer on GTir and DE (or something, im getting confused with it all). Wish I had all the parts and just see what fits, whats lightest and whats strongest.
hooray for engine rebuild and mi-goreng diet time!
ah if you didn't know though, win sam @ glen waverley has the cheapest instanoodles i've found. its just next to rock kung if you're wondering
but mi goreng is disgusting. but at $10/box, really cant beat that for cost cutting.
dat Daytona feeling.
Mt Waverly instanoodles, eh? I thought living in Balaclava was bad, new restaurants all the time, wanting to try most places. Clayton and surrounding suburbs got so many places its hard to even try a small % of them.
Guest
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
