hahahah. i meant the ones by hands... you screw up something early on, and then you need to recalc, look through tables again, and do all sorts of ceebs shiet. even worse interpolating, gah.
else have to matlab or some shiet for non-hand calc ofc. also not a fan :P.
doing a few questions on some airframe loads... iterations done and then READ FROM A GRAPH... initial c_l is like 1.113... after iterations etc you end up with c_l = 1.099, as if you can even read that difference on the shitty resolution graph they give you, all for the "huuuuuuuuuuuuuuge" difference it makes in your final answer...
hahahaha my knowledge of matlab is sketchy at best, i'm pretty good at simulink, but that's all.
you know what's f**ked up? ANSYS.
Don't ever mention ANSYS again! Bringing back my nightmares mang!!!
Yes that's a 156HP @ 183KG naked bike <3
$19,990
New price? If so, not bad for MV Agusta. Of you're going to spend that money, I reckon a Ducati Streetfighter is where it's at.
Or Speed Triple / Z1000 for nearly half the price...
Or a Monster 1100 EVO...
Either way, get another bike and this time make sure it's big and trackable.
sot sure if 1960's rock band........ or 2013 hipsters
i have read the posts.
hamish, rebuild the 991 3.6L and stroke/bore to 4.0L. first world 1% problem solved.
yes but i was thinking I could have the auto one for a daily and the RS 4.0 in manual...
Obviously I will need an RWB 930 track car aswell... I know it's more expensive to do it this was as I will have to buy 3 x prosches but I really do think it's the more logical option
combine reiteration question with
*insert typical engineering problem solving.jpg*
LOL
I would only go to that much effort in an exam. Every other time i'd be just meh. Or use answer from book and work backwards :P
Toby can I claim a bunch of stuff as business startup costs even though business hasn't made any legitimate monies. :P
Ed...actually.dont worry just remembered I don't need to claim anything..
Business startup costs have specific deduction requirements and claims. Its a bit complicated if you plan on doing it yourself.
Still a good idea to claim, so you can carry forward losses. Prob should be registered for GST too if you in losses
Need a big return again this year Tobes, got a lot of concreting to do lol
As long as you got receipts for your claims :P
Guest
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
