"Mr Reynolds' ruling does not affect the ability of police to conduct random breath tests, which has its own statutory power"
So all the police need to do is breath test the driver (pursuant to s 53) and then his argument fails
Also s 59 permits vicroads officers to pull you over :/
To be honest I was never much of a fan of the gtc's up until recently.
Though ive had a thing for Meisters for a while, anyway I'm not definite on any set yet, still looking, most likely Meisters at this stage.. This weekend will be full of looking!
And even if they public did win
Parliament will introduce legislation next week to rectify it :P
What are you, some kind of fancy law guy...
So...the Africans received compensation for being pulled over for no reason...and we pay to have our cars tested + unreasonable fines and time wasting...
When did import owners start having it worse than black people?
even if they do suddenly require a reason they will just say they spotted a skyline in the area hooning or similar
This happened to me on Christmas night last year.. officer said "we spotted a skyline in the area.. involved in some stuff"
That was actually what he said, it was as if he was trying to convince himself that was the reason lol
Carry a box of original glaze with you in the passenger seat. Get pulled over by cop, throw one out the window yelling "Go get it boy! Go get it!"
in queue for package pickup at mt waverly. the queue is so long people have brought their novels to read.
bad inventory or just lots of mail to collect on a Friday?
pumped my new beanbag. bachelor pad needs redecorating. less couch and more floor furniture. harder to get up from
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
