Is it a track day where you get put into groups then get times laps? Never been to a track myself so please noob it down. :)
yes they put you in groups.
they will ask for any experience when you say none they will look at the car and pick a group.
Auto Stag will be in one of the slowest ones.
then if you are too fast they will reclassify you during the day.
there is normally around 20ish ppl per group
you get a run approx every hour for 12-15 min, (which is all a car with stock cooling can handle anyhow)
so that 6ish laps.
you can have a passenger at any point in the day, so if there some-one you know who has experience throw them in the passenger seat for some advice.
same clothing as deca, long sleeves and helmet, leather shoes, the License you got for deca will work for there as well.
Timing is included, appears on a screen in the pits and is updated to natsoft online so you can check lap times later on.
Bar doing something like a driver dynamics day it's the easiest entry to a track day and the cheapest way..unless you break something!
oh and the melbourne cup Tampered day is going to be part of the MS championship.
Im replacing the whole interipr with a fairly rare black interior that I picked ip super cheap
Power windows needed replacing of the floor loom which connects the doors together along with everything from the front of the car to tje back of the car. So carpet had to come out. Which is interior out job anyways in a civic
So in return I got power windows and a black interior thats really saught after in the civic community. :)
My car is full of them rare parts. Hahah. Definitely will hold its value if I rver decide to part out.
My civic just looks like a stock civic to all you abos tho
because stock wheels.
Because its a civic
Can confirm I have no idea
And will still look like stock civic
And I own a civic lol
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
