ASUS G75VX
CPU: Intel 3rd Gen. i7 3630QM 2.4GHz (Turbo 3.4GHz)
OS: Windows 8 64bit
RAM: 32GB DDR3
HDD: 256GB SSD + 1TB SATA
Graphic:Nvidia GTX 670MX
3GB GDDR5 VRAM Dedicated VGA
Screen: 17.3FHD LED Screen(1920x1080)
UBB3.0 * HD Webcam* WiFi N * Blu-Ray Writer * DisplayPort * HDMI * Bluetooth
Awww yeah
I've just read up that the 4th gen intros came out. With dell Alienware being one of the first laptops to offer it.
Also new nvidia graphics card but that puts it to a price of $2500 :x
Might get the 4th gen intel and compromise on the gfx.
And no idea why ppl think I travel much!!!!!
I've never stepped outside of Australia! Stop complaining you!
Stagea brakes the same, better or worse then the GTT?
The latter..
Stagea brakes are more like na skyline/s13 brakes, single sided twin piston fronts, single piston rears
^ This man knows. :unsure:
Haswell worth it for the battery life for sure, man.
am thinking this one;
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389935#!tab=specs
Intel® Core™ i7-4700MQ (2.4 GHz, 6 MB L3 cache)
NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
15.6" diagonal Full HD BrightView LED-backlit TouchSmart (1920 x 1080)
Weighs 2.5kg but has haswell, 740M & touch screen for $1000~
or the 17" non touch screen
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389947#!tab=specs
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
