Does anyone here have a Python alarm? Mine works but the previous owner turned off the siren with the key and subsequently lost the key. Have tried a few different keys from different alarms but nothing works so I'm left to find someone with this alarm. PM me if you know anyone who does have one!
it's not that cold. gonna hit up manly and then a Brunswick-risqué housewarming party. expecting many Asian hipsters.
Yokohama Winton track day
http://www.yokohama.com.au/en/ADVAN-Motorsport/ADVAN-Neova-Cup/ADVAN-Track-Days.aspx
discount if you use advan tyres
Leigh, did you take your car to calder for the drags? Curious to know how fast my ship is...
Anyone else having a quiet night? Or am i forever alone.
Took it to Heathcote, pretty sure calder don't do drags anymore until summer!
Get farked Leigh
:D
15inch screen
Radeon HD 8970M 4gb gpu
i7-4800mq
16gb ram
256gb ssd
750gb hdd
dvd burner drive
$2500
Pro:
- Larger screen
- GPU twice as good as other option
- Slighter larger ssd
- DVD burner/reader
Con:
- Heavy
- Bulky to carry around
- $200 more
or
13inch display
nvidia gtx 765m 2gb gpu
i7-4800mq
16gb ram
240gb ssd
750gb hdd
external dvd reader
$2300
Pro:
- Lighter
- Smaller to carry
- Cheaper
Con:
- 3d card not as good
- smaller hdd
- external dvd reader
15inch screen
i7-4800mq
16gb ram
256gb ssd
750gb hdd
dvd burner drive
$2500
Pro:
- Larger screen
- DVD burner/reader
Con:
- Heavy
- $200 more
or
13inch display
i7-4800mq
16gb ram
240gb ssd
750gb hdd
external dvd reader
$2300
Pro:
- Lighter
- Smaller to carry
- Cheaper
Con:
- smaller hdd
Simple, first option if you can deal with the extra size. (nohomo)
am thinking this one;
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389935#!tab=specs
Intel® Core™ i7-4700MQ (2.4 GHz, 6 MB L3 cache)
NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
15.6" diagonal Full HD BrightView LED-backlit TouchSmart (1920 x 1080)
Weighs 2.5kg but has haswell, 740M & touch screen for $1000~
or the 17" non touch screen
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389947#!tab=specs
i was going to reply, but i see you have new options than the above...
i think i agree with leigh, if you can be bothered with the extra weight, probably worth it for the bigger screen and the gpu. not to mention if this is meant to be your daily work horse, you'd probably appreciate that extra screen real estate. not fussed about the dvd drive (heck, my pc doesn't even have one... ain't nobody got time for cd's)
Hey, yeah the more i research the more confused i get! and the more the budget gets pushed.
Now sitting at $2500 for a laptop; could get some nice rims for that price ~_~
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
