Nah man :laugh:
I only would want TE37's / Nismo LMGT's.
Where were you looking for wheels?
Tried to buy these rims:
http://www.skylinesaustralia.com/forums/topic/428204-rays-ce28n-18x95-15-cheap/
I only know two Jamie's
And I'm pretty sure it wasn't Jamie Lannister
So thought it might be you!
^You'd sell it to Jamie Lannister though; a Lannister always repays their debts.
Hey, yeah the more i research the more confused i get! and the more the budget gets pushed.
Now sitting at $2500 for a laptop; could get some nice rims for that price ~_~
The murky world of technology research before purchase. $2500 should surely get you what you want, now?! Haha. Pulled the trigger on anything yet?
There is a tv ad running at the moment which has a civic with type-r red integra seats. I think it's an EK? Haha
Yeah I saw that the other day...
Was LOL's!
Ah ok haha!
Yeah I am not in the market for buying wheels at the moment.
You tried Import Monster?
Yeah haha.
Cause I don't know what I want the laptop for; decided to pull back on the spending and get a learner laptop. Then upgrade to what I want/need.
Pre-ordered the 13" i7-4700mq, gtx 765mm 2gb 3d card, 16gb ram, ssd + hdd, win7.
Clevo w230st
Cost $1700 and will get a good idea over 6-12months if I'm chasing larger screen, gpu or CPU power.
I see!
That explains why the wheels you bid on sold so quick!
Try On The Run Motorsport..?
Sall good ill just run some cheapo rims
Something about spending the 1/4 value of your car on rims doesn't seem quite right
That or the wife will kill me
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
