He has also stated that in Scott's original, the viewer had trouble working out which characters were robots (replicants) and in his version the viewer "will definately be aware which characters are robots"
You know what that spells right? origin story yayyyy. Dark backstory, add some hatred for replicants with a garnish of disaster porn and you have Blade Runner 2: Apocalypse
Drove my first Porsche (only a cayman) today. Very low to the ground with small windscreen. Cockpit feels very similar to the s2k.
The PDK gearbox was cool, it rev matched on deceleration & gears changed without feeling anything
Handled quite well and suspension was firm. Could only imagine how much fun it would be with a proper engine :P
I did like the engine being behind, did sound nice when I gave it some poke
Still not as good as the R32 right? :P
It's a new day... still mad...
“The original movie was great in the 80s, but try watching it now next to movies like Attack of the Clones and The Last Airbender, and it really does feel lacking by today’s standards.”
When asked about casting, Bay’s keeping tight-lipped for now, although sources inside Hollywood say both Shia Leboeuf and Will Smith are in callbacks for the part of Rick Deckard, while Chris Tucker and Nicholas Cage have both been hinted at for the part of sadistic Replicant, Roy Batty (expected to be renamed: Roy Barry).
Asked how he plans to update the characters: “In the original, the robot characters really didn’t look or act much like robots – due to a lack of CGI options in the 80s. So you really had to use your imagination there. That was the first thing I wanted to address, and while I can’t give much away yet, lets just say you’re gonna know the robots in this movie are robots from the 21st century!”
Michael Bay – whose film credits include such groundbreaking works as Bad Boys (1995), The Island (2005), and Transformers (2007) – is no stranger to the sci-fi genre. He was reportedly first choice of Warner Brothers president, Alan F. Horn, from a shortlist of directors including Ridley Scott, Chris Nolan and Andrei Zvyagintsev.
/RAGEQUIT
hey victorians. thought id ask again... anybody have a pair of 235 40 18's laying around gathering dust? i need a cheep (relatively) pair for my spares...
hell ill take 245's.
please and thank you.
What about soft compound race semis? :)
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
