It was the 2012 2.9ltr model.
Did corner very well, much more planted than the r32. Could easily be used as a daily.
lol ofcourse it was more planted than the r32. its also a lot more expensive hahaha but you can afford it now
What about soft compound race semis? :)
BAHAH. i do need some of them eventually. (like nationals for the hillclimb) but now my priority is decent road tyres... i have 6 wheels, with 3 just above legal tyres and one good tyre that is making the car drive like shit... im gonna throw a pair of maxxis zr-1s on the front in 2 weeks, but i need to find two decent tread pairs for the rear.....
hey victorians. thought id ask again... anybody have a pair of 235 40 18's laying around gathering dust? i need a cheep (relatively) pair for my spares...
hell ill take 245's.
please and thank you.
I think i got achilles 123s 235/40/18 atm.
Though I need to get some new ones before I can get rid of these
What semis you looking to get rid of
i heard those are pretty bad with big displacement set ups.... but hey! ill give a go...
So put a deposit on one yet? :D
Some might say its a poor mans 911 Carrera, but others say its better!
Haha I'm a good 20yrs+ away from buying any luxury car. Can't afford to blow so much money on a depreciating asset (r32 doesn't count)
Need to invest for the future! /boringpathway
Was considering one as a daily for this very reason! Daily + weekender in one!
Reliability and expenses scare me though!
im in. lol was looking at atr sport 1's.... let me know when you pick some more tyres up!
Will do!
You look better in a Porsche when your 30 rather than 50 just sayin :P
Has a look at www.pelicanparts.com
Have been buying BMW parts for my dads car from there. Very cheap spare parts in the states. I would assume similar for Porsche parts too.
Will do!
Haha in that case I have 5 years to make it happen then :P
God knows where I will be in 2 let alone 5.
One thing I do predict, the r32 will still be around! :P
Cool! Still, dat mid mount engine...seems like pain in the ass to work on.
Other than that, you got an awesome all rounder and better looking than the Carrera IMO. Older models still look good and the S isn't too bad on price.
Day 1 of not having a job.
What to do?
Nothing. You're off the grid. The absolute freedom and ability to do anything you've ever dreamed of in this short life is so infinite and full of potential for regret, that you will ultimately end up falling into a daily routine of nothing because you fear your overwhelming choices. Then regret doing nothing in the end. Enter depression, for that vicious cycle touch.
  • Like 1
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
