I had this but gave it up for experience & challenge
Nothing worse than being bored/comfortable at work within your peak years. This is the time to explore, challenge and make mistakes.
Work to live or live to work.
I prefer to be challenged at work as long as its paid well. Hence why I'm off to the mines.
9days @ 12hrs & 5 days off.
Come at me brah
yeah each to there own, I consider myself lucky I like what I do, am good at it and earn a decent enough quid out of it.
Median wage for 2012 I think is about $50,000
Or $60,000 for full time employees
Still quite high imo
You can live quite comfortably if you were a couple on $60k each. That's if you dont have a big arse mortgage
The Min wage to wait on tables full time, is 44k/yr or 47.5/k if you add in the super. That doesn't include any overtime etc.
Even that wage isn't bad as a couple to be basically on 90k combined if you are living/working out in the burbs. Agree CBD travel would suck to the outers (40mins+ on train for eg if you chose to do that)
This country is f**king wages insane.
Exactly
Money should never be the only motivator for work because the high will wear off and you will be working more hours making you even more depressed.
Motivator should be doing what you like and expecting the company to provide the respect and recognition of what you put in.
That way both parties win.
not a smoker myself.
oh so hookers then :P
infact I was planning on watching Anthony bourdain's the layover for Amsterdam tonight!
cool... good episode that one... his constant statements about not being stoned are classic
look into the houseboat idea
lol says the guy that has to pay people now :P
12 months ago you would have had a different view
My view has always been people in this country are overpaid for a lot of jobs.
My base rate at my old job was 55k per year and i had a f**ktonne more responsibility than someone waiting on a table for only 9k difference!
I couldnt/wouldnt work in hospitality. Plenty of other jobs with less skills and shitloads more bludging, I think waiting on a table earns their dollar (in some restaurants) and thats why i dont tip :P
Exactly
none of the bold, but no fks given its a dog eat dog world i do what i gotta do and not a thing more.
/selfish
having said that i did the opposite going above and beyond previous employer got me nowhere so fk that.
Edited by alr33x
Agree with this. I don't know what people do with their money...blow it on unnecessaries, alcohol on the weekend, or overseas trips? Would love to see some monthly budgets!
When I was working a 40k a year job and my mate was on 80k, we were both living at home and both putting away 2k a month in savings...go figure!!!
I understand inflation and cost of living rising, but it's been slower than the wages surely. We now have office secretary / admin roles bringing 60k to the table and people still think that's too low. How can people feel they deserve so much for so little? Still have 50k planted in my head as a decent salary from when I was a kid lol. If people can't get by on 100k combined these days, they either have some serious addictions, or are living way outside their means / have high expectations about what it means to be a young couple.
I blame YOLO
Guest
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
    • Not without making up a new screamer pipe from scatch I don't think based upon the angles of the current return. Backpressure shouldn't be an issue though as the straight gate isn't affected by backpressure in the same way that a poppet valve is, and on top of that the exhast system is 4" all the way through so there should be minimal pressure if any to begin with.
