^^ THIS!
Can confirm driving Euro is a slow death. Current daily is a 2001 auto astra.
Had to put this in my driveway for a day or two to remind me of what its like to drive a real car (even though its technically euro... but I guess so is a honda accord)
If it makes you feel any better, it's powered by Japan :)
haha yeah forgot about that. old had k series, then 2ZZ from corolla sportivo + supercharger, now they're running their own 3.5L V6.
best 4 cylinder setup I've driven by a mile. but I wouldn't buy one...
Actually the V6 is not a lotus motor either.
its the V6 from the TRD aurion
http://en.wikipedia.org/wiki/Toyota_GR_engine#2GR-FZE
So an aussie developed version of a Jap motor in a euro car.
o rly? wasn't aware of that. probably best to leave the important stuff away from the Brits :P
paper work is filled in.... just need to get a bloody passport photo! so ill have to post it monday....
Good work Paul. What is the next event your planning on entering?
FYI I just used a Facebook picture and sent that via email :thumbsup:
very clever.........
no idea tbh. im actually selling my skyline as i join sau...
but once the clubby is ready and i have all the cams gear for the car then ill look! might have a go at the hill climb at nats, other than that havent got a clue! i want something cheap and easy for my first time in the hsv. shes a big girl.
Hitting up No 2 on the list today for lunch:
http://theburgeradventure.com/top10-2012/
burger van that going to be up the street from work!
Looks tasty!
So an AD-JD-EUDM Car :rofl:
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
