very clever.........
no idea tbh. im actually selling my skyline as i join sau...
but once the clubby is ready and i have all the cams gear for the car then ill look! might have a go at the hill climb at nats, other than that havent got a clue! i want something cheap and easy for my first time in the hsv. shes a big girl.
All you need is a cams approved helmet, fire extinguisher and some stickers and off away you go!
As for tracks, IMO Winton is easier for the beginner but Sandown is convenient because its so close
calder in a couple months as well, and this is a pretty good beginner track.
yea not a fan of concrete lol.
wont be going to hard as its my daily hahah! well i have a couple of helmets in the garage, hopefully one of them will work.
have a fire extinguisher in the boot, but yea need to have a bracket knocked up to bolt one to my pasenger seat...
have a magnetic battery sticker, just need one for tow....
would love to do a driver dynamics day as a refresher, but cannot justify 300 at the mo!
Never been to calder park
Is it mostly grass for run offs or concrete walls?
main straigh has plenty run off as it the drag straight, well was last time I was there.
rest is grass then concrete but it all straight line braking. it's really a very simple track.
shit condition tho thanks to 0$ spent on it and drifters.
You'll be fine
My first track day was Sandown in the wet in the daily R34
Just take it easy and you'll be fine!
So i see
Count me in then!
Stolen from his FB
But SAU VIC member Chris Madden has been driving this around.
1016655_10151453840572050_1308600656_n.j
Hnnng. The only thing tempting me to f**k responsibility and blow cash.
/will wait for labour to unf**k FBT so I can salary sacrifice that bad boy.
Must....resist....purchase
seriously tho aaron, you can have my 33 for 4350!
reg till nov! :woot:
ill even help you drop a manual in if you dont like the worked auto.
Lol the only boat I would buy is one that floats on water
Bit of press on the FBT changes
Im curious as to know your understanding and explanation on how and why this effects you?
Just trying to gauge the understanding of the changes from the public's point of view
Aaron you should pay attention as this change will effect you
Along with everyone else on your team that gets company cars!
Company pays FBT, and technically we are paying for the car as its apart of our salary and not as a benefit. Ie I can choose to be paid more and not be given a car..
My understanding is that tax is paid on default 20% private use for a salary sacrificed car.
The changes would mean I need to calc the private:business use; when salary sacrificing car I'm not using it for business but 100% private.
That's my understanding of it.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
