pfft... sif not take the kanye jizz, shove it in some chick, marry her then sue for child support and have a rich-ass kid to mooch off
amateurs
Now I ain't sayin you're a gold digger...
2 more days until full license, finally get to drive my car! If my P's expire on the 24th, does that mean I can drive on the 24th, or wait until the 25th?
i'd start driving now, tbh, bahaha. within reason.
http://aca.ninemsn.com.au/article.aspx?id=8693684
hehe someone has a varex exhaust in that vid. Cops picked up on it; not bad...
Bleh
Typical ACA...put up the footage of low intelligence people swearing contrasted with police showing concern for the community.
I lol'd at cop's comment about it being dangerous to the community because the cars can't stop...didn't see anything in the report about faulty brakes??? Is that the best reason the cop could come up with as to why they defect cars for modifications?
Loud exhaust is fair enough to an extent...can see how that pisses people off. Though it's still overpoliced when the legal limit is ridiculously low, and I personally don't agree with the law.
But the other stuff they are defecting them on...they really have to come up with the worst excuses to justify it.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
