lolwut thats just silly
I reckon the alienware one is bit cooler
http://www.youtube.com/watch?v=0Xwe5jGBa5g
3:15 or there abouts, kinda shows (just the first random vid i found on youtube..)
/nerdlineaustralia
I've just got a M-ITX system.. it shits on most rigs out there and the size of a shoe box lol
pfft who buys PCs as a package.
rebuilding mine in a few months once car is sorted. All it needs is new hard drives and a new graphics card because my choice of cards was poor and cant find similar cards to SLI. Save those monies. Had an i7 920 for a while now and barely breaks a sweat, The SSD was one of the first out during the price drop and im pretty sure its the root cause of my PCs hiccups every year or so when I need to do a reimage.
I used to have a i7 920, great CPU now I've got one of the newer i5s (actually quicker than older i7s) new GPU is a 660ti good bang for buck compared to my 2x 5850s
Edited by UNR33L
I've a Sandy Bridge 2600K, and video card is a 560 Ti with 448 cores (essentially a 570), still going strong :D. Only built a year and some months ago. Got enough cooling ready to go for when I want to overclock as well :D
Murky world of Haswell laptops is what I need to look into this semester, urgh.
I've got a haswell laptop on Pre order. Been delayed 3 weeks due to high demand of CPU.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
