Maybe my area is also still 147 (-4c)... Think dad just got home, maybe he saw. *goes to check*.
In other news, got a grade that was lower than I expected for one of my units. I was certain I should HD it, lols. Email lecturer etc, turns out some error in their spreadsheet wasn't taking into account one of my assignments...
So if I hadn't thought something was odd, and taken initiative, this wouldn't have been fixed, I would've had a lower grade and shit, no-one the wiser... Can not trust the system at all these days...
Well as it turns out, it WAS indeed an HD, so :P
Depends on the subjects. Arts I expect nothing less than HD's, Eng I try to maintain at least D's. So they don't write me off without an interview or something :'(
Yet end up being so lazy in-semester. Every semester will "be different"... but nope hahaha.
I have 16 cent / litre vouchers muhahaha
If anyone in eastern suburbs wants a 10 cent / litre voucher, I have a few of them too.
Yeah i got a 17c one from woolworths the other night. Something is going on.....maybe the supermarket petrol retailers using the price per barrel hike as an opportunity to try squeeze a few more independents with these tasty discount vouchers.
>spends $5 fuel driving to birds for 10c voucher
>saves $3.37 at petrol station
>profit!
Except he lives close enough on the way to places that it's the other way around, at least :P
I think I live slightly closer than from yours even, judging by last time direction when he said he dropped by yours when he dropped off my bike :P
haha was just guessing, no actual math done (slow day too) - then again my car is sitting on 16l/100 i suppose.
I live about 8 minutes from Birds I'd say.. I live in dat dere Wantirna / Knox danger area hence me not owning a skyline
Thinking gym > kebabs tonight..
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
