haha was just guessing, no actual math done (slow day too) - then again my car is sitting on 16l/100 i suppose.
I live about 8 minutes from Birds I'd say.. I live in dat dere Wantirna / Knox danger area hence me not owning a skyline
Thinking gym > kebabs tonight..
Only 16/100?
Drive it harder.
Lol, think the most i've ever had it was 16.8 or something keep in mine this is mostly city traffic purrs along at 8 on the hwy
Reminds me need petrol for my bike too, on the way to work this morning light popped up -_- dam you no petrol gauge!
Intel suggests the Coles servos on Bwd Hwy are 149.9 for 91... So 165ish for 98, I suppose.
Haha my bike has a fuel gauge :D... But no clock shits me.
Swap you a clock for a working clutch
i dont know if this is a stupid question for bikes, but dont you just take the cap off and have a look or tap the outside and hear if its empty? its just a lawnmower tank, right? :P
Or light up with lighter.
to some extent you can depends on what type of bike, dirt bikes kinda yea.
my road bike stores fuel even under the seat lol, most road bikes you can only tell when they're pretty much full or half full the other way you can tell is how the bike
rides too
best bet is just use the odometer or wait till the light comes on if no gauge :D
Edited by UNR33L
Still not fixed, bro? :(
Also, can confirm my earlier Intel was correct. 98 was 166.9. I successfully located my 10c voucher luckily.
Nope, only have a cold wet muddy carport to work in, and only weekends to do it. Need to make sure I can have it done in 1 day so I'm not leaving it without a clutch cover
Pretty sure you're <5 min away, if not less, from me then, lol.
Haha I'm at the gym atm. Best of both worlds.
You two are about 500 metres from each other. 5 minutes would be a walk.
Also 10 cent voucher = about $6 in 60L tank
16 cent voucher = about $10
Shit adds up if you use them everytime.
Definitelt worth stopping by Birds' house when in doubt of vouchers.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
