haha and there you go, hallo neighbour.
nuh uh, you guys join goodlyf, it's the bomb. most people i know that go to other gyms (or even other goodlifes) that come down to this one say it's pretty neat :)
nah brah staff are way nicer at ours
You'd better kill it with a burnout...... and post a vid
can't kill rb20s brah, I tried :P
164.9 for 91 !
cot dayyyym!
nick you still got that golf diesel for sale? :P
Haha not for sale yet, maybe in two weeks? You BUY! :P
Broken gbox lol
Yeah, but I finally managed to get a refund from that f**khead wrecker on Monday.
Getting another box from a more well known place in Adelaide which should arrive end of this week and then no more problems
inb4 Hamish says anything about RP
LOL!
What the ...... I filled up with fuel at 5:20pm near home, 147.9 - left less than an hour later to go to meet & drove past it was 160.9 ?!?!?!?!?!?!?!?
Tell me more about how there is not price fixing...... *eyeroll*
place is pretty crappy, owned by some asians now.
Like the store isn't updated. Lol
You wanna see a not up to date servo, try the Mobil? I think it is in Bridgewater. Place doesn't look like it's seen a renovation since the 70s
That I want to see.
hEY Az...kebabs was tonight hey...i forgot about it and had to eat some Horrible sweet chilli fish...because the dickehead stuffed our order up and put sweet chiilli on it instead of lime and chilli...now everythings stinks and I want a kebab
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
