katoui... HOW f**kING BULLSHIT WAS YESTERDAY. f**k.
was soooo gee'd up to see him live... and his E30 in the background lol
Yeh :(
Was bull shit lol, we who got tix first didn't get a show, while extra show on Thursday did.
was gonna paint my rocker cover this weekend. did a practice run with the wrinkle paint on a piece of steel. It was flat and still f**ked it up... cant imagine doing it on small spaces. leave it to the pros me tinks
It's a cold weekend... Did you use a heat gun to bring out the wrinkle while it was drying?
yeah, did it in the sun yesterday and let it bask between coats then finished it with a heat gun. was gonna use BBQ for actual rocker cover, but seeing how uneven the spread was on the test subject, decided it would be best properly suspended and with decent prep-work since the cover is already painted, just chipped and starting to peel.
It's not that tricky... I just rubbed mine back with some of that green brillo pad stuff to get rid of the corrosion buildup, then wax and grease remover, then sprayed it with wrinkle black according to the directions on the back... Then hit it with the heat gun for a few minutes... keeping the heat nice and even.... it'll take a while, but pretty suddenly it'll reach the dryness point where it starts to wrinkle... you'll see it spread over the surface as you move the gun around.
Before:
705168_10151101013706148_1187555115_o.jp
Painted:
530994_10151101012971148_1067307599_n.jp
After:
I also did the crossover pipe, BOV and R34 strut brace in black wrinkle... and the exhaust manifold head shield in high temp black as well. Came together really nicely, looks clean and still looks almost stock until you put it next to a real stock car :)
I painted dat strut bar bro :P
I think with wrinkle the best results I've had have been cleaned & prepped well, preheated with heat gun so it's warm to touch then coats in the order it says on the can with 5 minutes and a bit of heat between coats, then heat as final and let it sit and cure for 24 hours or so, otherwiseeven if it feels hard it;'s still soft underneath the top layer and you can actually tear the surface and move the wrinkle leaving shiny bits if you're not careful.
Guest
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
