Wait... So is this the car who's owner posted above? Why's it saying in the article that its owned by the Tran twins?
http://www.worldtimeattack.com/index.php/open-class-byp-racing-honda-civic/
(I'm surprised it's not running an SR20... though I guess they do pull a premium before WTAC...)
The article says BYP is owned by the twins
I stand corrected... Article is pretty vague however... If its going to be their promo car, they sure are ripping him off a lot... and if the EG has moved on from BYP, that WTAC article really shouldn't still be there promoting the car... That said, it was probably written over a month ago..
Drove my first Porsche (only a cayman) today. Very low to the ground with small windscreen. Cockpit feels very similar to the s2k.
The PDK gearbox was cool, it rev matched on deceleration & gears changed without feeling anything
Handled quite well and suspension was firm. Could only imagine how much fun it would be with a proper engine :P
I did like the engine being behind, did sound nice when I gave it some poke
they sorely need more power though, they are gutless wonders.
Was considering one as a daily for this very reason! Daily + weekender in one!
Reliability and expenses scare me though!
bosses ones have been fairly reliable (3x cayennes (2 diesel, 1 GTS) + cayman + 911 turbo)
only real issues have been the radio/bluetooth randomly dropping out/not connecting.
Average wage is a rort.... It is skewed by high income earners and not corrected by people on negative income
Median wage is just over $50k which seems somewhat legit.
FWIW the average wage in ACT is $85k (no prize in guessing why)
i dont make the average wage for the ACT.
dissapoint :(
Can confirm driving Euro is a slow death. Current daily is a 2001 auto astra.
Had to put this in my driveway for a day or two to remind me of what its like to drive a real car (even though its technically euro... but I guess so is a honda accord)
yes, but its a euro with a toyota drive line. so its not always broken.
The GPS unit is f**king useless too.
Way to play catch up in Vic wl.
500k borrowed for first home? Is this normal? Don't these hypothetical young couples have a decent deposit?
even my normally fairly broke ass will only be borrowing ~300k on my first place in a year or two. who needs their first place to be worth 500k + deposit.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
