The GPS unit is f**king useless too.
Way to play catch up in Vic wl.
i will also add, having to accept that stupid warning not to use it while driving every time you start the car. fark offfffff you flamin mongrel of a thing.
Cliffnotes:
-Mohsen makes bad decision #368
-Frank Ocean
-Hamish living dreams vicariously through son
-Simon still in relationship that ended months ago
-Pat is like John Farnham retiring; said he was gonna fk off years ago, still around
-Martin comes to Australia for a holiday
-Aaron overreacts to something; driving a free expensive European car sucks
-Frank Ocean
-Skateboard store at Knox has sale, worth it for defect?
-Jono overcapitalises on first car; Honda is still gay
-Leroy says something obscure and/or black
-Dezz wants his tax return, will post again next EOFY
-Frank Ocean
-Rimon / Bruce Banner AWOL
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
-It's not a car, it's an Alfa Romeo
-Birds has too much time on hands; needs full time job; didn't buy a jeep
  • Like 1
Cliffnotes:
-Frank Ocean
-Frank Ocean
-Frank Ocean
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
That's pretty much perfect lol
Cliffnotes:
-Frank Ocean
-Frank Ocean
-Frank Ocean
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
excellent summary. A+. expecting seasonal summaries.
Cliffnotes:
-Frank Ocean
-Frank Ocean
-Frank Ocean
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
:laugh:
gotta hate when cars do this shit:
Shit cunt cars. This is the cause of so many accidents and I hate seeing it even driving in my car. What's the point of indicating if you turn the wheel as soon as you do?
Not to remove any blame from car, but bike rider really shouldn't have been closing in on his blind spot slowly like that...either sit behind the car or in front of it. Ride defensively! I only say this because I expect cars to drive like f**king idiots / not realise the dangerous weapon they are in charge of.
at southland today and lady infront took entry turn too hard and hub cap flew off, hit a parked car on the grill and ran up the bonnet. wasnt sure if ti was hard enough to scratch paint, but you'd be pretty cut if you came back to your car to find someones hubcap on the bonnet.
aftermarket hubcaps are aids anyway.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
