Whys it on a space saver?
Rafs civic was on a space saver once.. couldn't even get a jack under it unless you did a run up and sort of speared it into the car
Puncture. My car is above legal height. So all good with the space saver hahaa
f**king balls, the course at VU I'm after is no longer available, cbf paying 4x the price other training providers want. Same with other course I also want, again at least 4x the cost... Time for different direction me thinks.
Need moar jumpers/hoodies as 3/4 of my collection is shrinking/past its use by date.
And want another GTR, godamnit.
repost.
yell and scream at them, then jump up and down all angry like a little.
Haven't played monopoly in ages, wasteland monopoly night???
You mad Titan?
Would be moaning more if petrol prices was like up north, isn't moaning healthy or good? Remember reading somewhere or someone telling me about it...
Cliffnotes:
-Mohsen makes bad decision #368
-Frank Ocean
-Hamish living dreams vicariously through son
-Simon still in relationship that ended months ago
-Pat is like John Farnham retiring; said he was gonna fk off years ago, still around
-Martin comes to Australia for a holiday
-Aaron overreacts to something; driving a free expensive European car sucks
-Frank Ocean
-Skateboard store at Knox has sale, worth it for defect?
-Jono overcapitalises on first car; Honda is still gay
-Leroy says something obscure and/or black
-Dezz wants his tax return, will post again next EOFY
-Frank Ocean
-Rimon / Bruce Banner AWOL
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
-It's not a car, it's an Alfa Romeo
-Birds has too much time on hands; needs full time job; didn't buy a jeep
can you provide these summaries every few pages. very handy.
Cliffnotes:
-Frank Ocean
-Frank Ocean
-Frank Ocean
-Audis
-Wheels
-Fuel sucks
-Cash Train
-Simples
wow....just...wow...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
