Nah from an insurance POV the Mazda would be at fault due to the bike already being in the lane. The driver of the Mazda should be aware of his surroundings at all times when merging and not just in the prior head check.
Bike hasn't done anything wrong by going in the next lane and speeding up.
ahhh yes. undertakes a car (illegal) then blames car driver because when he looked it was clear.....
waits for shit storm...
Passing on the left on a multi-lane road is not undertaking and perfectly legal
and this is why the drivers in australia are some of the worst in the developed world.
Edited by Plattsy
also last bit of trolling for the day.....
The rider of a bicycle must not ride past, or
overtake, to the left of a vehicle that is turning left
and is giving a left change of direction signal.
technically the car was doing this as he got level with it. so in the eyes of the law he is undertaking and therefor in the wrong....
Whilst I fully agree, I must give in to my inner Ozzy and tell you to 'Gobackhomethen you pommy git' :P
i love ya man! and you know im more aussie than you, cos chevy, but this is ridiculous man... the bike isnt even in the left of his lane! i agree with birds on this one...
May as well keep feeding the troll...
Do you not understand "And"? The car is not turning left -and- giving a left change of direction signal, he's changing lanes.
And most developed countries have the same rule, except it's for passing on the right for the LHD countries.
Yes the bike could have positioned himself better, but doesn't make how he rode illegal
Also he started changing lanes prior to indicating, so still the driver is in the wrong.
True dat.
The first thing I got taught in the HART rider training course was to never sit in a drivers blind spot, and to never travel in the left lane. Car drivers have issues seeing a bus let alone a motorbike in their left mirror.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
