Hmmmm DECA.... Considering Shockworks Coilovers and Whiteline Bushes before then... Wonder if its possible within a month, working full time?
Have already done the 4 Rear K-Frame and the 4 Diff Bushes with Whiteline goodness... So just Arms and a few other bits and pieces to go?
coilovers arent too hard to fit, but still needs alignment.
doing bushes DIY... yeah have fun with that :P
How do the shockworks coilovers compare the the BC ones?
Richo runs BC coilovers, seems to be good enough for him at the track
Coilovers I've got no troubles fitting...
Bushes, I'm not going to try ghetto remove any bushes that should to be pressed, ever again ;) Mike (Miguelone) and I spent a full afternoon trying to get the suckers out of my K Frame...
https://www.facebook.com/photo.php?v=10151330100116148&set=vb.641676147&type=3&theater
I've heard some very good things about them, local support is nice, they're only a few hundred more than BC BR's.
Currently I'm running Bilstein Shocks and Springs, I'm about 3cm too low at the zorst, I'd like something damper and height adjustable which is still silky smooth for the street (which my current setup isn't). Car was imported in 2006 with the Bilsteins on it, so they're getting pretty old I'd say.
Fair enough!
So now that your car is sorted when you coming back to the track?
yeah coilovers would be a pretty good upgrade. picking the right ones for daily use is the tricky part I reckon.
sif coilovers.
i got brand new bilstens and am getting eibach progressive rate springs.
silky smooth for daily duties and not too rolly for corners.
Guest
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
